GTM Coupe Rebuild
GTM Coupe
GTM Coupe Rebuild
Post by GTM Coupe »
Here is a montage of photos taken during the rebuild for anyone that is interested.
Steel body was blasted back to bare metal and primed, modifications to the fuel cell were made as there were no baffles in the tank, front subframe was blasted and repainted
Front rebuild (Small).JPG (48.37 KiB) Viewed 12345 times
Modifications to suspension included on car adjustable bottom arms and caster bars, new pickup points for the coilovers, complete refurbishment of the brakes
Front upright.JPG (52.21 KiB) Viewed 12343 times
Replacement of std radiator (allegro) to new style rad, new header tanks and accessories, modification to the braking system to allow for dual circuit brakes
Front end.JPG (53.32 KiB) Viewed 12333 times
GTM Coupe
Re: GTM Coupe Rebuild
Post by GTM Coupe »
Full rebuild of rear suspension and braking system, drums replaced with discs, fabricated hubs,caliper mounts and handbrake system, fully adjustable suspension on car
Rear suspension 1 (Small).JPG (47.83 KiB) Viewed 12321 times
Custom made dash, will be fibreglassed or flocked once finished, haven't decided yet
New Dash 2 (Small).JPG (50.24 KiB) Viewed 12316 times
Fitment of seats, custom sliders made to reduce overall height
GTM Coupe
Post by GTM Coupe »
Engine apart for examination and rebuild, a few surprises found once opened, but all in all a good start point
Eng stripdown (Small).JPG (48.98 KiB) Viewed 12295 times
1430 MED Full race unit, A+ block machined,decked,etc,etc, omega pistons on Cooper S blanced/shotpened rods, ARP bolts, nitrided,balanced,wedged,crossdrilled crank, heavy modified head with offset Rimflow valves 37mm inlet 32 exhaust, ported, polished. Billet steel lightened flywheel (NZ made) bilet steel backing plate, MS sintered clutch/grey + diaphram, MS SCCR gearbox, SC drop gears,crosspin diff, hardy spicer outputs
Block and box (Small).JPG (28.89 KiB) Viewed 12296 times
Dummy fitment of engine so that exhaust manifolds and exhaust system could be fabricated
Engine in car 2 (Small).JPG (36.11 KiB) Viewed 12290 times
GTM Coupe
Post by GTM Coupe »
Engine in and working, 45 webber on 6.5" ali manifold, custom exhaust and manifold
Engine 1 (Small).JPG (42.81 KiB) Viewed 12284 times
Side view of car, started on the rub down not finished yet, new wheels on order, possible wheel arch extensions
PICT0091 (Small).JPG (71.86 KiB) Viewed 12284 times
Rear view, spoiler required, some modification to boot lid and scoop
PICT0094 (Small).JPG (71.77 KiB) Viewed 12280 times
Looks like your doing a great job. How much of the body is steel?
GTM Coupe
Post by GTM Coupe »
Basically only the tub is steel, the rear is a spaceframe setup, the front is just a mini subframe. The rest of the car is fibreglass. Its so light that when the engine is not in the car 2 people can pick it up and move it.
Great photos, best of luck with it.
There used to be one driving around the Dun Laoghaire / Dalkey area in the early 90's, although I haven't seen it for years.
One sold in Sligo earlier in the year, it was on a Q plate which is as big a headache as no papers at all. I think it went to the East coast.
GTM Coupe
Post by GTM Coupe »
DSCF1336 (Small).JPG (50.06 KiB) Viewed 11928 times
DSCF1341 (Small).JPG (36.41 KiB) Viewed 11928 times
DSCF1344 (Small).JPG (54.96 KiB) Viewed 11934 times
GTM Coupe
Post by GTM Coupe »
DSCF1355 (Small).JPG (52.51 KiB) Viewed 11920 times
DSCF1350 (Small).JPG (43.81 KiB) Viewed 11917 times
DSCF1348 (Small).JPG (27.77 KiB) Viewed 11913 times
Nice car, and a nice little garage too.
Why the change of top shock mounts ?
dermow
Post by dermow »
Hi there
Good to see another GTM project in action.
You seem to be on top of things at the moment, more than i can say for mine.
I'm trying to put a Yamaha R1 engine into mine and as you know there is very little room
in the engine bay.
If you want to cast your eye over it go to the General section and on page 6
you will see a thread called FRESH MEAT.
Hope we can share some info in the future.
Dermot
If you build it they will come!
GTM Coupe
Post by GTM Coupe »
Dermow,
Yeah I've seen your one on GTM Forum, my username is Andy on that forum, didn't realsie that you were on this side of the ditch, where are you based.
GTM Coupe
Post by GTM Coupe »
[quote]Nice car, and a nice little garage too.
The original ones are only there to support shocks not coilovers, I found that they were bending with the upward movement, I also didn't like the way they were made as there were made from 2 pieces welded together at the weakest point. The new ones are a one piece design. Its all trial and error with these cars, I'm still playing round with the coilover settings so it my not be the last modification.
dermow
Post by dermow »
I living in Portlaoise so not a million miles away from you.
GTM Coupe
Post by GTM Coupe »
Well I can't believe its taken me this long to post some more pics,
Right so I flipped the car over and atacked the rust, usual spots the 4 sill corners,
Then it was sealed,
I wasn't happy with the brake setup so I installed a pedal box,
I then continued sandblasting the interior ready for primer,
Changed the rear light to a more modern replaceable unit,
GTM Coupe
Post by GTM Coupe »
Then i applied a fine primer coat to stop the rust,
I then modified the locking arms on the rear suspension as I didn't like the original setup,
Then came the lovely task of body prep, the single longest time spent on one task,
GTM Coupe
Post by GTM Coupe »
I then packed all the bits onto the truck and took it off to be painted,
Parts in primer,
Spraying the car,
Parts painted,
GTM Coupe
Post by GTM Coupe »
Ok so it now safely back in the garage,
Now I needed to apply the stone gaurd to the wheel arches and spray the engine bay (to save money)
And the finished result,
GTM Coupe
Post by GTM Coupe »
Now the fun begins, putting all the gear back on,
[IImage
miniireland
Post by miniireland »
excellent write up andrew, sorry i couldnt make it up i was stuck in a bloody classroom all week, give me a shout if you want me to drop up any evenings next week...
Si...
great build gtm... can't wait to see this on the road... :D
GTM Coupe
Post by GTM Coupe »
miniireland wrote:excellent write up andrew, sorry i couldnt make it up i was stuck in a bloody classroom all week, give me a shout if you want me to drop up any evenings next week...
Si...
Thats no probs Si, it was really just a sugestion to get you out of the house and into a garage so you can get your hands dirty, I'm working on it most evenings after works (or when the wife lets me) so give me a buzz and come over.
Excellent work, keep us updated
GTM Coupe
Post by GTM Coupe »
Right a few more progress photos,
Front brakes plumbed,
Clutch plumbed,
Started on the cooling pipes,
