1990 mini auto
skelly
Whats your location?: Moville
Co.donegal
What Minis have you?: 1968 irish mk2
1980 blue mini 1000
1990 mini auto
Post by skelly »
havnt had a mini on the road now for a while,so while im getting the green one
finished ibought this one lastnite,
its a 998cc auto it has 51000miles its in pritty good shape
the passanger door needs a new skin and there some bits of surface rust.
goina drive this now till the other is finished an then ill do what ever needs doing to it.
theres a limerick address on the nct form so some1 mite know the car.
igot it afew miles down the road from me
Re: 1990 mini auto
not so bad, u shoulda brought it on the economy run today!! up the auto!!!
Re: 1990 mini auto
was that on done deal?? that has a cam and high lift rockers!
Re: 1990 mini auto
Kenneth Murphy wrote:was that on done deal?? that has a cam and high lift rockers!
i hope it has a cam!!
Re: 1990 mini auto
high lift cam
skelly
Co.donegal
1980 blue mini 1000
Re: Seen a Mini?
Post by skelly »
Yea thats the 1 kenneth. The young boy that had it just lived over the road from me.
Re: 1990 mini auto
nice!best of luck wit it!!!
skelly
Co.donegal
1980 blue mini 1000
Re: 1990 mini auto
Post by skelly »
the starter gave up on the auto so missed the paddys day run. ihad an other one to fit it but when iwent
to remove the old starter the nut and the bolt where both turning so the starter was going no where.
ive to take the engine out to try and remove it now.
so ibougth the 1275auto that was for sale there and im putting that in now when iget the other engine out.
started stripin it last nite just the driveshafts to remove now. hope to have it all done over the weekend and back on the road next week.
skelly
Co.donegal
1980 blue mini 1000
Re: 1990 mini auto
Post by skelly »
the 1275 is in. ifinally got it fired up l.nite, had alot of trouble with the babjo for the oil feed.
the threds were nearly all gone on the block. some1 had tryed to put a bigger banjo bolt in to it to, :evil: igot the next size bolt an tryed that with no joy,still wasnt catchin enough to hold. got a kit from work to re do the threds,the only1 icould get to fit was an other size bigger. i took the bit iused to the hydraulic shop an the old banjo an he made me up anew1 with hydraulic pipe. it worked perfectly :)
so after alot of messin an head scratchin it fired up last nite, just have to set it up right now to day. an hopefully get it out spin.
thanks keith an unfit for the help and tips
PAUL D
What Minis have you?: 1979 850 deluxe
Modifications: group 2 arches,semi dish steering wheel, comics,plenty of chrome bits!
Re: 1990 mini auto
Post by PAUL D »
Bring it for a spin over to mine :wink:
skelly
Co.donegal
1980 blue mini 1000
Happy birthday
Post by skelly »
Got the car on the road this mornin. The 1275 sounds great. Starts first turn of the key with out the choke. Have 3gears. It wnt go into drive. So have 2play round with the cable 2nite an try 2sort that. Door skin 2replace next and tidy up the surface rust. Got new set of 12x5 superlites on it they look good. Fingers crossed il get the gears sorted 4 mtm. Be along run at 30mph
Users browsing this forum: Ahrefs [Bot] and 7 guests
