i'm new, heres what i've got.
mikko
Whats your location?: belfast
What Minis have you?: 84 city
Modifications: b16a1 vtec
Post by mikko »
just finished my dream of 15 years or so, a vtec mini, well nearly finished, still some loose ends to tie up and get it taxed. heres a wee vid and pic.
ok people turn up your volumes for this :D
Re: i'm new, heres what i've got.
sweet, did u extend the front or is it still standard, whats it puttin out??
mikko
Post by mikko »
dont like the look of extended fronts so kept it normal, engine and frame are gonna have to come out to change the oil filter as a result but small price to pay imo. its a b16a1 out of a crx, some people say it puts out 160 bhp but i think its 150 which is plenty for what i'm after.
defo looks better with out the extended front, alot of work involved??? wouldnt mind a vtec mini meself!!!
mikko
Post by mikko »
aye quite a bit of work involved but any1 with a technical head could do it, i'm no engineer and have never done anything like this before but the 16v mini forum is such a help. i'd highly recomend the conversion if you enjoy your tinkering. i done it on the cheap (about £1000) but some boys go to town with them.
Nice sleeper you have there Mikko,the name in white on the tyres is a nice retro touch.
i want one :D :D :D :D :D
kona
Post by kona »
How did it work out so cheap??? Id consider doing it at that price, have you upgraded the brakes and gears? how did you sort out the driveshafts?
in england people dont look silly money for hondas!
kona
Post by kona »
Kenneth Murphy wrote:in england people dont look silly money for hondas!
So , you are better off going up north and buying a Vtec then just scrapping it down here? As fun as it sounds, removing the engine to do a oil change, or probably anything else is a bit too much work for me :(
mikko
Post by mikko »
a rough breakdown:
engine, box,ecu and loom etc -£300
driveshafts (incuclding cutting, sleeving and welding)- £200
gear selector mechanism-£20
injection fuel tank-£40
civic fuel pump-£30
speedo, clutch cable, speedo cable-£100
standard front subframe and steel to make frame-£50
metro 4 pots-£100
and about £200 on hamerite, pipes, tubes, wires, cutting/grinding discs,nuts/bolts, straight thru exhaust 2"
i'm sure i've forgot things but thats the gutz of it.
well done on doin that on that budget, any1 wanna give me £1000?!?!?!?!?!
Well done on getting it done on such a tight budget,did you make up the driveshafts yourself or get a firm to make them and did you get them balanced.Just want to know as I am starting by own 16v conversion soon.
miniireland
Post by miniireland »
jeez it must be very tight under that bonnet, any pics, :shock:
mikko
Post by mikko »
heres the instructions i brought to the machine shop, got it from 16v mini forum i think, along with 2 mini and 2 honda shafts and required lengths. they are not balanced but the sleeves were turned down to be perfectly round and the sleeves themselves keep the whole shaft dead straight.
mikko
Post by mikko »
will get some engine bay pics up when i take some.
very sweet job.... . have u any construction pics of the subframe & suspension?
Mark
Post by Mark »
Great looking Mini! Any pics of under the bonnet?
Have you thought about running a remote oil filter in a slightly easier to access place?
mikko
Post by mikko »
just came back to look at my breakdown of costs as i'm gonna build another 1 for mate and seen some pic requests.
heres some pics:
scotty_1987
Post by scotty_1987 »
nice mini mate..bet it gives some wanna be racers a surprpise!lol :mrgreen:
nice work on it as well
Whoaaaa! that's a tight fit! very impressive. *respect*
