1964 Racer
dayoungfella
1964 Racer
Post by dayoungfella »
Well after the smash I had at the Phoenix Park Races in August 2009, I've put the racing on ice for a while and decided to put my money into something with a little less risk and that I can get better value for money out of. And so, here is my 1964 mk1 Morris Mini Deluxe!
I bought the car from a guy in Cork who brought it over from Wales in July 09 and never used it. The previous owner had modified the car to make it look similar to a Works Rally Car but didn't really go to extreme lengths, which is great because it would have been a shame to undo all the hard work that would have gone into it!
It had a few unoriginal parts fitted like an A+ 998 engine, later type wiper motor, homemade dashboard, Group 2 arches, 100+ wheels and a few other little bits and pieces - but was largely a standard car.
I was surprised to find that the car was 99.9% rust free but this is due to having had a LOAD of replacement panels in its day - some of which were not fitted very well! But that doesn't bother me too much as I wasn't looking for a concours winner.
Here are some photos of what it was like when I bought it.
The dismantling starts.
So, the plans for the car are to make it look like an FIA spec mk1 Cooper S, with the engine, gearbox, and running gear from the race car.
I have many of the parts already to achieve this but some of the parts will have to be bought down the line.
The car will be used for weekend blasts, track days and possibly the odd historic race or two!
Here are some photos of what I’ve done so far.
The final spec of the car will be as follows:
Shell:
-1964 Morris Mini Deluxe in Cherry Red with black roof
-Safety Devices 6-point rollcage
-Twin Cooper S fuel tanks
-Standard glass except for laminated front screen
Exterior:
-Morris Cooper S badges
-Morris Cooper S grill
-Stainless bumpers with Cooper S overriders and corner bars
-Stainless rear opening windows
-Cooper S Stainless door window surrounds
-Chrome arch trim
Interior:
-Standard red Deluxe seats (until I can afford something else!)
-Black carpets, door cards and dash panels
-3 clock centre binnacle with original Smiths clocks (will upgrade to Cooper S 130mph speedo eventually)
-Smiths Tacho with dash pod
-Mota Lita John Cooper Signature 14” steering wheel with stainless spokes
-Black 3-point harnesses
Wheels & Tires:
-10x4.5” Rosepetal alloys
-165/70/10 Avon CRZ Sport tires
Brakes & Suspension:
-Cooper S master cylinder
-Braided lines front and rear
-Cooper S callipers and discs at front
-Minifins at rear
-KAD handbrake quadrants
-Standard subframes front and rear
-Ripspeed hi-los front and rear
-Standard cones front and rear
-AVO alloy adjustable dampers front and rear
-Heavy duty tie bars at front
-Minispares adjustable bottom arms at front
-KAD camber brackets at rear
-Standard rear swinging arms at rear
Engine & Gearbox:
-MED A+ block bored to 1380cc
-MED full rally spec head
-MED fully worked crank
-Centre main strap
-Standard balanced rods
-AE 73.5mm pistons
-Swiftune SW98 cam
-Swiftune 1.5 roller rockers
-Swiftune duplex timing kit
-Minispares 2 core rad with auxiliary fan
-13 row oil cooler
-Aldon electronic ignition
-Aldon Flame Thrower coil
-Facet Red Top fuel pump
-Twin HS4 carbs
-Maniflow 2” LCB with straight through Maniflow exhaust
-Minispares lightened flywheel and backplate
-Grey clutch diaphragm
-Paddle clutch
-Minispares straight cut drop gears
-Minispares straight cut gear set
-Standard diff with hardened pin (will be changed to Salisbury LSD eventually)
-3.7 final drive
-Standard pot joints (will be changed to Hardy Spicers when LSD is fiited)
Will update this thread as the build continues!
Neil
(You forgot to uncheck the "Disable BBCode box".........................sorted TMG)
Re: 1964 FIA Lookalike
The links are broken! :(
dayoungfella
Weird, they're working on other forums :shock:
Lovely looking Mini Neil, I especially like the wheels. 8)
dayoungfella
The Marcos Graveyard wrote:Lovely looking Mini Neil, I especially like the wheels. 8)
Cheers Neil! The wheels are the best part...I've already ruined 2 wheel nuts though due to damaged studs :evil:
nice, they all u'r cars in the garage??
dayoungfella
daniel garry wrote:nice, they all u'r cars in the garage??
I wish! I share the workshop with a few other Mini nutters...there's room for a few more if anyone's interested? PM me for details.
Neil
Are you going to sell the 998 engine and +100 wheels ? very sweet motor by the way :D
dayoungfella
CLUBMANGT wrote:Are you going to sell the 998 engine and +100 wheels ? very sweet motor by the way :D
The gearbox has been sold but the engine and wheels are still up for grabs if you're interested.
The engine ran very smoothly when I test drove the car, no funny noises etc. Not sure what mileage is on it though so would take €50 for it.
The wheels are in good condition with perfect Camac and Daytona tires. Will take €100 for them.
mad-mini
Modifications: ALL IRISH CARS
Post by mad-mini »
hi wat ar u doin with the seats in it???
wat sort of money is on the workshop??
Good work, keep us posted
dayoungfella
mad-mini wrote:hi wat ar u doin with the seats in it???
I'm keeping the seats for now until I decide what to do with the interior.
Will send you a PM now about the garage.
This is really a lovly car, best of luck with the project :D
INNY1300
Post by INNY1300 »
Hello Neil,good luck with the project,it will be lovely when finished with the spec you have planned,and a cracking garage as well,regards jon :twisted:
92Coop
Post by 92Coop »
:shock: WOW.
Absolutely love it Neilo. Its gorgeous!!
Shame about the racecar :( (and the racing too)
Is the white fella salvagable? (the shell i mean)
I miss him :(
dayoungfella
Hey Maxi!
The white fella is easily fixed but probably need a full respray at this stage. I've had a few people interested in buying the shell but I'm not too pushed on letting it go. I could live to regret it!
Would love to turn him into a racer again down the line but it might be cheaper to just buy a car already built.
92Coop
Post by 92Coop »
yay :mrgreen:
stewart
Post by stewart »
Hi Neil
Have really enjoyed watching your build everything was going sooo fast and looking really great
I can really see the GOODWOOD influences here
But what has happened has it been too cold to get out to the garage
Stewart
dayoungfella
A combination of things has slowed down progress lately...work, weather, delivery of parts etc.
I hope to have the interior, brakes, suspension and a few other bits of trim finished by the end of this weekend as well as having the engine ready to go, bar the set of twin HS4s I'm waiting for in the post!
The other bits I'm waiting on are mirrors, steering wheel, chrome wheel arch trim, air filters, hoses, oil cooler and a load of other small bits and pieces.
Will get more pics up asap!
Neil
I asked Pierre to have a word with you about that engine i hope that was alright :?:
By the way I am a fan of the older cars and your build is the dogs danglers nice one .
I cant believe the speed with which you got it built :!:
neasha
What Minis have you?: 1988 Austin mini mk3
reshelled 998 jetblack special edition
Modifications: Stage 1. Sportspack replica archs - 13" sportspack wheels. Over rider kit on bumpers.
Half leather interior, Center console and wooden dash, clear lens.
Post by neasha »
That is lovely:D
dayoungfella
Thanks for the comments! Still no real updates though unfortunately :(
Got the carbs and my new steering wheel finally but any time I've spent on the car over the last few weeks has been problem solving!
The biggest issue is getting the 7.5" discs to fit my hubs as they are fowling them badly. Will have it sorted this week though hopefully.
One of the other issues has been trying to get my quickshift to work! It doesn't seem to want to go together again after being removed from the racer. Will probably just go with a standard shifter for now.
Hope to have the engine ready to go over the weekend so will try get some new pics up.
Neil
PS-That's fine Tony :wink:
hi neil, very nice mini!! did the cowl suit ok??
dayoungfella
Well, I finally have an update!
Ended up getting some 2nd hand hubs from Paul Hickey which I've now rebuilt with fresh bearings and ball joints and fitted to the car. Just need to find the correct bolts to fit the calipers and that'll be the running gear sorted.
KAD sent over a new gearstick as the last one was dodgy so will have the gear linkage fitted soon.
Carbs are now on the engine and will hopefully have it ready to fire this weekend.
Still have to finish off the interior with 2 new purchases:
My John Cooper signature Mota Lita steering wheel...
...and my works style Smiths tacho...
And one little job I have managed to do is fit my downton mirrors!
Will try and update again after the weekend.
Neil
I still have that wiper motor if you need it, I brought it to the Kilmainham Jail run, but had to bring it home again. :roll:
Users browsing this forum: Ahrefs [Bot] and 26 guests
