1430 Cooper
sid
Whats your location?: Bray
What Minis have you?: 1430 Cooper
Modifications: Not enough!
1430 Cooper
Post by sid »
Thought i better show a few pics of my mini.
Original '91 carb'd cooper when i got it, this it before it went for re-spray and tidy up.
Stripped out ready for respray
When i got it back
Went for the 13x7 sportspack look, which i now kinda regret, probably change to 10's in the near future.
Recently changed to Anthracite 13x7's, similar to these
Body:
91 Cooper shell resprayed metallic green (Not quite BRG)
Sportspack arches
MK II Rear lamps (Not in photo's)
Chrome brightwork
Wheels & Tyres:
MWS superlites 13x7 Anthracite centers
Yokohama A539 175/50x13 Tyres
Brakes & Suspension:
Standard Callipers
Green stuff pads
Braided hoses (bought, still to be fitted)
Rear minifins
AVO adjustable dampers front and rear
Hi-lo's front and rear
Heavy duty adjustable tie bars
Minispares adjustable bottom arms
KAD rear camber brackets
Engine:
Very standard 1275 with stage one kit fitted but i have started collecting bits for my 1430 build
Fully prepared blocked bored to 73.5mm
Cooper ‘S’ rods and Omega pistons
MED fully worked 84.3mm stroked crank
MED Rally spec cylinder head with 37mm inlets and 30mm Exhausts valves
Double valve springs
Swiftune high lift roller tip rockers
Piper HS270 cam
Duplex timing kit
Aldon electronic ignition
Standard gears
Four pin dif
Only recently started building this engine up, hopefully have it all up and running for the MTM.
I will keep this thread updated throughout the build, have a few bits done already and some pics.
Will post them up when i get them on to the computer.
smur89
Re: 1430 Cooper
Post by smur89 »
The respray looks really well. How much did it set you back do you mind me asking? And where? Thinking of getting it done myself
miniroar
Re: 1430 Cooper
Post by miniroar »
Alright Sid whats the crack rory here love the wheels!! still have'nt fitted them yet still working on the new mini,cars lookin good will be a beast when your finished!
Re: 1430 Cooper
num num!!! good paint job, it'l be a rocket wit the 1430
Re: 1430 Cooper
just curious how come ya regret the 13x7 look???
Re: 1430 Cooper
mustard wrote:just curious how come ya regret the 13x7 look???
Think its more the ride handling Paul
Here's a few more Sid
Re: 1430 Cooper
Bored to 74mm and you have 73.5mm pistons?Not goina be much compression in that engine!
sid
Re: 1430 Cooper
Post by sid »
Regret cutting nearly half the (then) perfectly good front wings away so i didnt get tyre rub!!
I know its a mini and all, plus i need new front cones but the 13x7 give a seriously uncomfortable ride!!
Still like the look of them though, me's thinking about (when the engine is done) of switching to
carbon fibre look miglia arches, love the look of these with the cut lip...
sid
Re: 1430 Cooper
Post by sid »
BERT wrote:Bored to 74mm and you have 73.5mm pistons?Not goina be much compression in that engine!
Sssssshhhh Image
neasha
What Minis have you?: 1988 Austin mini mk3
reshelled 998 jetblack special edition
Modifications: Stage 1. Sportspack replica archs - 13" sportspack wheels. Over rider kit on bumpers.
Half leather interior, Center console and wooden dash, clear lens.
Re: 1430 Cooper
Post by neasha »
Really nice mini.
sid
Re: 1430 Cooper
Post by sid »
Got some pictures uploaded,
This is the engine when I got it, it had been rallied for a short while and then sat up.
Started stripping it down the other week
Found one of the cam lobes completely worn down, didn’t mind as I was replacing it anyway.
Everything else looked ok,
Cooper S rods
MED crank and centre main strap
Re: 1430 Cooper
I'd say the thing is a weapon to move! Where abouts in Bray are you from?
Re: 1430 Cooper
nice lookin engine Sid, cars looking great too, some nice acceleration as it is so this new one will be a right stormer!
its got some nice porting work done on the head too!
sid
Re: 1430 Cooper
Post by sid »
macker wrote:nice lookin engine Sid, cars looking great too, some nice acceleration as it is so this new one will be a right stormer!
Cheers macker, standard engine i have at the moment is a peach, never given any trouble!!
Hoping the new engine will have a good bit more poke!! :lol:
sid
Re: 1430 Cooper
Post by sid »
Engine painted up and new cam fitted ready to get timing sorted!
Re: 1430 Cooper
Oh yes! Engine looks class Sid.
Re: 1430 Cooper
sweeeet!!!!!! :mrgreen:
Re: 1430 Cooper
Well did you get the engine timed yet Sid?
Re: 1430 Cooper
Nice motor, thought that was Berts trailer I saw in the pics ok, engine pics confirmed that .
Is that the motor he had up in his place ? should be a stormer anyway . :D
sid
Re: 1430 Cooper
Post by sid »
CLUBMANGT wrote:.
Yep thats the one!
Timing set up now, hopefully get the engine back up to the
garage tomorrow and do a bit more on it at the weekend!! :lol:
Re: 1430 Cooper
Good man Sid, would offer some help but i'm back in work tonight :x
Re: 1430 Cooper
Get the finger out :!: :!:
Re: 1430 Cooper
Well any progress Sid :?:
Re: 1430 Cooper
i have a set of the fibre glass arches cut for a clubman if ur interested
sid
Re: 1430 Cooper
Post by sid »
StevenR wrote:Well any progress Sid :?:
Small bit of progress lately, got the gearbox back off Llyod after getting reconditioned,
All casings where sandblasted and then laquered. Gearbox mounting holes drilled out
to accommadate 5/16 bolts
Engine is now on the gearbox, but still waiting on getting my rocker post spacers.
Was meant to be getting them through Llyod off MED but they were taking ridiculously long
Ended up getting them off Paul Hickey so should be able to get the valve timing sorted soon.
Back to work tonight :( but have a shift off the following weekend so hope to get some
serious progress then, will keep ya's posted!!
