problem
karl
problem
Post by karl »
hi
well,finally got my first insurance today and am well chuffed.decided to go out with my dad to take it for a spin,was out 15 mins and i could feel the clutch getting softer,has come to the point were it wont go into gear at all.does this mean new clutch or has anyone had a similar problem?
karl
madjackjr
Re: problem
Post by madjackjr »
Sounds like the hydraulic fluid leak check the level of fluid in the reservoir and look around the clutch housing for signs of fluid spillage
karl
Re: problem
Post by karl »
got my dad to pump the pedal while i looked for leaks.i can see a rubbery washer that fluid seems to be leaking from.its were the clutch slave cylinder is???sorry not to good with mechanics
karl
madjackjr
Re: problem
Post by madjackjr »
Yip thats the problem you lost hydraulic fluid. Is the washer on the flexible hose going from reservoir to the clutch?
karl
Re: problem
Post by karl »
ye just were the clutch engages you can see fluid bubble.is this a big job to fix??
just_st3v3n
Re: problem
Post by just_st3v3n »
karl wrote:ye just were the clutch engages you can see fluid bubble.is this a big job to fix??
no, easy.. fill the fluid back up to normal level... you could just tighten the nipple (the little nut where the fluid is leaking from) and check if it still leaks but more than likely air will have got in so you will need to bleed it as follows:
get ur da out to give you a hand.
get the right sized spanner and place it over the nipple (where the fluid is leaking from) - turn and open the nipple a tiny bit so ya get a drip of fluid coming out, tell your father to push in the clutch and hold it there- while he holds the clutch pushed in you close the nipple, tell him to release the clutch and repeat untill your happy that there is only fluid dripping out..
(from past experience, took about 3-4 go's)
NOTE@: make sure to put a rag or something underneath the nipple to catch the fluid, the fluid eats through paint = BAD
hope that does the job for you,
enjoy :P
steven
some day....
karl
Re: problem
Post by karl »
thanks a mill for the reply.i think im after feckin the whole thing up as the nipple keeps turning like the threads are gone?will this need replacing now.thanks for the help.was lovely being able to drive it till this happened. :oops: :oops:
Re: problem
Hi Karl,
it would probably be best to replace with a new slave cylinder, they're not expensive and once its replaced it'll be a worry off your mind,
judging from what you said so far it sounds to me like the rubber plunger inside the slave cylinder had perished anyway,
its a common thing to happen on old slaves when they havent been used for a while,
once replaced, just bleed it through and you'll be right as rain :D
karl
Re: problem
Post by karl »
thanks for advice macker. is it a job i could do myself reason being i just spent a sickening amount trying to get it rite!!!.is there any where localish i could pick one up?sorry bout all the qs :lol:
Deadly Dave
What Minis have you?: 1990 Black Checkmate 998cc
Re: problem
Post by Deadly Dave »
karl wrote:thanks for advice macker. is it a job i could do myself reason being i just spent a sickening amount trying to get it rite!!!.is there any where localish i could pick one up?sorry bout all the qs :lol:
Its a good starter job and easy to do. You will then know how to bleed brakes too. Try a local motor factors for the part. What area are you in ??
Deadly Dave Image
karl
Re: problem
Post by karl »
im in stillorgan. in dublin.
Re: problem
is your clutch Verto or non Verto?
this is the one you'll need for a Verto,
http://www.minispares.com/Product.aspx? ... tle=CLUTCH SLAVE CYLINDER VER...
and this is the one you'll need for a non Verto,
http://www.minispares.com/Product.aspx? ... tle=CLUTCH SLAVE CYLINDER NON...
karl
Re: problem
Post by karl »
its an 84 city.not too sure
Re: problem
when you look at it does the plunger part push a long arm or a short arm connected to the clutch housing?
Long arm - Verto
Short arm - non Verto
:D
beadles
Whats your location?: " half way between panic and sheer blind terror"
What Minis have you?: "RUSTY" an 88 city in garage undergoing surgery . "Beadles" A late 80's early 90's City Automatic
Shell on the driveway, some of him in the garage more in the shed and the rest of him
in the attic
Re: problem
Post by beadles »
Karl
i'm in mount merrion and may have a new one, i'v sent a pm with my mobile no
call me i might be able to help you out
Is it a coincidence that mini and money start with the same letter? 'cause if you have the first you sure better have lots of the other
kona
Re: problem
Post by kona »
If its a non verto it could be worth mentioning that there are a alot of other bits that wear and snap.
The plate that the slave mounts to can snap.
The Plunger and the ball that goes into it can wear.
The bolt that pulls the mount to the flywheel cover can snap too.
I think you can get a repair kit for the slaves, I know that I got one for my non verto. cost like £5. The new slave was almost £50.
Deadly Dave
Re: problem
karl wrote:im in stillorgan. in dublin.
Ashgrove Interparts , Kill Avenue would probably be able to get the parts for you next day.
Deadly Dave Image
karl
Re: problem
Post by karl »
thanks for all the help lads.much apprieciated.got it all sorted today.
ian o B
Whats your location?: strokestown road
co. longford
What Minis have you?: 1995 jap-imported spi cooper
1974 Australian clubman panel van - still in oz
Modifications: Adjustable gaz shocks and adjusta ride height, 6x12 deepdish minilights ultimate engine steady, grp 2 arches, maniflow exhaust.
Re: problem
Post by ian o B »
:lol: the same thing happined to me last week!!! :x :lol:
Re: problem
Well if it happened to yourself and Ian just after the two of yous got insurance yous may feck off if yous think yous are passing on the bad luck to me next week when my policy starts! :lol:
Re: problem
ha ha bets now taken if it happens to stan
karl
Re: problem
Post by karl »
HA
the first day the vent for the heater fell off.and today had a few wires burn on me!i was convinced someone doesnt want me driving it... :lol:
ian o B
co. longford
Re: problem
Post by ian o B »
StanO'Toole wrote:Well if it happened to yourself and Ian just after the two of yous got insurance yous may feck off if yous think yous are passing on the bad luck to me next week when my policy starts! :lol:
well now with the gearbox out of ur one i think you got it worse dan us :lol: nle ting different was you were drivin before insured!!tut tut.. :lol:
