mini keeps cutting out
bkeo
Post by bkeo »
Im just after getting a second mini a 1990 mini studio 2 998cc .
Heres the story when im driving along the road the car will stop going, it still revs when you press the accelerator but will go nowhere.When i pull in it will cut out and will keep cutting out as i try to take off.
I put in a different fuel pump but it didnt make much of a difference. I was told it might be the coil but the car shouldnt be able to start at all if it was the coil or would it ?
Please Would anyone be able to tell me what would be causing the car to stop running when im driving.
Thank you
When you say the car stops going i assumn you mean the engine is still running but there is no power in it. This sounds like a fuel problem alright and is proberbly at the carb.Fuel starvation can be caused by a dirty in line fuel filter if fitted (not standarded) or dirt in the float chamber on the side of the carb. Alternitivly dirt in the piston chamber can cause the needle to stick open and have a similer effect.
best of luck.
nannyc
Post by nannyc »
that happened to mine too same story just kept loosing power, turned out to be the points!!!
bkeo
Post by bkeo »
Thanks for the replies
I dropped the car down to a local mini mechanic on Friday because i was getting nowhere .I changed the fuelpump ,coil and cleaned out the carburator and it got me nowhere.The mechanic put a new condenser into it and blew back the fuel pipes to get rid of any dirt and it went perfectly
but things went from bad to worse today and now the car wont even start..After i left it for a while it started but when i tried to start it agin later it wouldnt startI know its not the battery cause i tried it with jump leads and it made no difference.I think its probably the starter motor or yhe points but i am open to corrections would anyone have an idea what would be causing this as i dont have a clue.
Please any ideas appreciated as im going out of my mind
nannyc :ill try to check them tomorrow as the car dosent seem to have as much power as it should and ill do anything now to try to get it going
nannyc
Post by nannyc »
k what mine was doin was exactly like yours, it just kept loosing power and cutting out, when it was turned off starting it again was pure luck, after a few trys it'd go but it was dodgy after replacing all the things we could think of it turned out to be the smallest thing.... the points, its worth a shot!!! good luck with it
Mini 850
Post by Mini 850 »
if the engine turns over its not the starter. sounds like an ignition problem to me as nannyc said check your points and if they are good check the gap, also check the condition of your dizzy, rotor arm, plugs and leads. has your car been out in the rain????????? if so possible damp in your dizzy would cause it to run like poo
bkeo
Post by bkeo »
Problem sorted swapped the spark leads from my other mini today today and adjusted the points as ye pointed out and also adjusted the timing and shes running perfectly now.So happy now that i dont have to worry about breaking down on the side of a dual carrigeway agin.
Thank you nannyc & Mini 850
bkeo
Post by bkeo »
More bad news today i felt the mini wasnt running right so i got a fellow i know to take a look at it and i found out the head gasket is one its way out so i have to fix that straight away and hopefully she should be good to go agin next week.
Theres always something, never mind, hopefully nothing else will go wrong while the head gasket is being changed, you'll need a new exhaust manifold gasket as well and hopefully the manifold nuts will come off handy enough.
Are you doing the job yourself ?
bkeo
Post by bkeo »
No a mechanic i know said he'll do it for me he used to work on minis before so he said he'd do i for me.
Do motor factors store these parts or will i need to go to a mini specialist.
Is there anything else i shoulg get while this is being done
nannyc
Post by nannyc »
i got most of my parts in the auto factors no probs.
bkeo
Post by bkeo »
Thanks for that nannyc ill can call around to one of them tomorrow and see if they have it cause i wont have time next week cause i have college exams
