service
- What Minis have you?: 1992 SPI COOPER
service
i need my mini serviced the rockers adjusted and the tracking adjusted the problem is i dont have much money and need someone to do it on the cheep does any one know someone who could do it thanks
Re: service
i sorted someone out for the service but cant find any one to do the tracking any ideas where does tracking on minis
- Deadly Dave
Re: service
Most tyre centres have the equipment to do a full geometry setup but most of the operators dont know one end of a tie rod from their ar$e.markcaffo wrote:i sorted someone out for the service but cant find any one to do the tracking any ideas where does tracking on minis
Deadly Dave
Re: service
i got a really nice tracking done in ISA Motors, (http://isaautos.com/Contact.html) in Blackrock, CO. Dublin. friendly, understanding and competent. They took their time and did it right. I will go back there again.
Re: service
im in the same boat.. went to atlas on the kylemore road just today.. 40 quid and my mini still throws me into the path when i let the wheel go.. went back straight away.. and still no improvement.. so its a no on that place! how much did ISA charge ya keith?
Re: service
Had mine done in ace tyres sandyford €60 its a four wheel digi machine
sound lads always do a good job for me anyway
Re: service
Ouch, it's just 35 Euros at Glanworth Tyres, Mallow on their 4-wheel laser tracking machine.TONY R wrote:Had mine done in ace tyres sandyford €60 its a four wheel digi machine
- BlackSe7en
Re: service
The local tyre Dealer (I don't mean ROVER , Longbridge) at the IMM , changed 4 tyres, balanced the wheels, fitted 4 new chrome Tyre valves and tracked the front wheels , all for £40. They weren't too put out that I hadn't bought the tyres off them as they didn't have any Mini tyres in stock.
I just came across the small garage on the way to the Village Pub to meet the wife on Saturday, after been let down by a bigger Tyre business at the other end of the road.
Re: service
30 euro, and they used the old "clamp to the rim" yoke with mirrors... I phoned beforehand to make sure they weren't busy, and they did it while i waited: the owner (peter??) was well chuffed with seeing a mini, so he took it for a spin after to "check" the roadworthiness.karl123 wrote:im in the same boat.. went to atlas on the kylemore road just today.. 40 quid and my mini still throws me into the path when i let the wheel go.. went back straight away.. and still no improvement.. so its a no on that place! how much did ISA charge ya keith?
between them and Donnely Tyres in B'rock (dublin, to our country readers!) i'm sorted!
for years i used to deal with a well known chain of tyre and exhuast "specialists" but two incidents, the latest one when they tried scaring my wife into replacing a perfectly good 200 euro tyre convinced me to shop around.
Re: service
atlas did the clamp the rim thing with the mirrors.. and i would have been better off doing it myself with a shaving mirror.. or one of those mirrors at the funfairs that make u look about 2 foot tall!
but ill wait til im free next week and i might pop out to them unless anyone has any better suggestions!?
Re: service
i'd suggest if you are not happy with the service you got, go back to them and explain.... and get them to do it again.. its entirely possible they made a mistake. only fair to them to allow them rectify it: only fair to you to make sure its done right and you are happy?
- Deadly Dave
Re: service
It sounds like they may have only adjusted the tracking. If it pull to one side then it is more likely that the camber settings are off.karl123 wrote:im in the same boat.. went to atlas on the kylemore road just today.. 40 quid and my mini still throws me into the path when i let the wheel go.. went back straight away.. and still no improvement.. so its a no on that place! how much did ISA charge ya keith?
Deadly Dave
Re: service
You need to see if the front and rear wheels are in line, measure from the centre of the front wheel to the centre of the rear wheel check it's the same length both sides.
Re: service
[quote="karl123"]im in the same boat.. went to atlas on the kylemore road just today.. 40 quid and my mini still throws me into the path when i let the wheel go.. went back straight away.. and still no improvement.. so its a no on that place! how much did ISA charge ya keith?[/quote]
ive been to them once or twice
got them to put on my straight through exhaust, afterwards i noticed my handbrake felt a bit strange, turned out the pleb who put on the exhaiust (crooked may i add) had got the handbrake bcable caught in the exhaust pipes!!
stay away!!
stay away!!
Re: service
You need to go somewhere that uses the 4 wheel laser system...
Get them to make sure all your angles are whitin the parameters...
Camber angle castor angle and Wheel alignment(Tracking) can be a nightmare and all have an effect on your steering.......
Those Dunlop guages with the mirrors are good enough for Wheel alignment(Tracking) but not near as accurate as the 4 wheel laser system....
The laser system will tell you exactly how your 4 wheels are sitting in relation to each other, Even if they are not 100% in line with the shell of your car they will still steer perfectly once they'r all in line with each other
I forgot to mention
You need to have someone operating the system that actually knows what theyr doing!!
I forgot to mention
Jonesy
Re: service
thanks for the help lads i think ill give that place in blackrock a try
