Radiator Issues
Radiator Issues
Hi all
So my 96 Mini Cooper almost overheated yesterday and when I checked under my bonnet I noticed that the radiator cap had spewed dirty rusty water everywhere. I let the engine cool, and then refilled the radiator and that got me home, but I heard gurgling noises coming from the radiator when I switched off the engine an checked the radiator cap. It was hissing steam. And on checking the water level sure enough it was very low again.
So I suspect the radiator cap (as there was steam hissing out there when I arrived home) and I have a new one on order.
Is the rusty water a good sign? I suspect not. How can I clean up my water and prevent that happening in future?
Any other tips to help me sort this issue out? Any an all help is greatly appreciated!
Cheers!
Cheers!
Re: Radiator Issues
Could be something as simple as a broken thermostat ???
Re: Radiator Issues
I'm not sure how that would work. Had zero issues until yesterday with the radiator in the year I have owned it, and a week or two ago I removed the radiator cap to check the water level. Might I have damaged the cap seal then perhaps?steeo wrote:Could be something as simple as a broken thermostat ???
- Deadly Dave
Re: Radiator Issues
As Steeo said it could be a stat problem. They are cheap enough so its worth while replacing it anyway. Dont forget to put antifreeze in when refilling as this prevents corrosion in the cooling system.
Deadly Dave ![Image](http://ermopoli.it/portale/images/Ermopoli/smilies/zicon_rambo.gif)
Re: Radiator Issues
Cheers lads.Deadly Dave wrote:As Steeo said it could be a stat problem. They are cheap enough so its worth while replacing it anyway. Dont forget to put antifreeze in when refilling as this prevents corrosion in the cooling system.
What exactly should I look to order? I use minispares.com so if anyone could give me a bit of direction there I'd appreciate it.
What is the ratio of anti-freeze to water, and any recommended antifreeze? That might sort out the corrosion issue I'm seeing with the rusty water.
- Deadly Dave
Re: Radiator Issues
Your local motor factors would probably have or can get in the parts.dragonfly78 wrote:Cheers lads.Deadly Dave wrote:As Steeo said it could be a stat problem. They are cheap enough so its worth while replacing it anyway. Dont forget to put antifreeze in when refilling as this prevents corrosion in the cooling system.
Antifreeze ratios would be 30:60 AF :water up to 50:50. You might aswell flush the system when you are there too.
