anyhoo here she is, had her 2 years so far and am saving at the moment for a big engine!!!
Coonos Cab wrote:Thats a lovely looking Mini there, Buddy![]()
Interesting to see the high reg number. I don't expect we will be seeing such a huge record of new cars being registered in one year in the near future.
Funnily enough, regarding oil leaks.... Having a Princess and a Dolomite already I'm used to the odd seep of oil from time to time BUT since the Mini arrived it's not shed so much as a drop of oil![]()
If you did put too much oil in, it would potentially cause a seal to blow.
Perhaps drain some out, ensure engine is cooled down and dip the level. When refilling, pour small amounts in at a time, allow to settle and then dip again.
Might be no harm to drain it all out and replace the oil filter also.
Process of elimination etc![]()
Tony.
PS-don't hang about attending to that surface rust on your front/rear valances and door bottoms. Prevention is always better than cure!
Buddy wrote:i took the pictures last Saturday after a run with a few lads from miniresource in bray!
macker wrote:Buddy wrote:i took the pictures last Saturday after a run with a few lads from miniresource in bray!
*Ahem*![]()
