1972 Pickup project
steeo
Re: 1972 Pickup project
Post by steeo »
Front calipers
Grubby looking calipers
caliper 01.jpg (20.2 KiB) Viewed 6873 times
20 minutes in the blaster.
caliper 02.jpg (19.8 KiB) Viewed 6868 times
Coat of paint
Coat of paint
caliper 03.jpg (27.12 KiB) Viewed 6875 times
steeo
Post by steeo »
New pistons and seals all round
caliper 04.jpg (24.18 KiB) Viewed 6874 times
Calipers came up really well. Great job. 8)
Thats the beauty of a blasting cabinet,maybe when the pickup is finished you might take up the blasting as a nixer. :D.Great to see progress with the pickup Steve.Not enough commercials around these days.
How about this for a commercial :lol:
steeo
Post by steeo »
Looking at making up my own cabinet soon, the one I have at the minute is a bit small and restrictive.
I am also looking into Dry Ice Blasting, a mate has a large garage that I can rent and am just waiting on information and pricing to come back to me from the suppliers.
steeo
Post by steeo »
Well had a bit of spare time on my hands yesterday so I got it into my head to strip the drivers door and see actually how bad it was but I ended up stripping the skin off as the bottom of the door has seen better days.
mini 4.jpg (20.94 KiB) Viewed 7153 times
mini 1.jpg (28.05 KiB) Viewed 7151 times
mini 2.jpg (25.66 KiB) Viewed 7148 times
steeo
Post by steeo »
And more
mini 6.jpg (25.24 KiB) Viewed 7150 times
mini 5.jpg (15.93 KiB) Viewed 7138 times
mini 3.jpg (27.7 KiB) Viewed 7136 times
steeo
Post by steeo »
I'll be looking at the passenger side one next and also the door I bought of Woody so hopefully 1 of them will be better than the drivers side.
steeo
Post by steeo »
I have been looking at Somerfords prices for door skins and the have 3 options
1. Genuine skin @ £54
2. Non-Gen skin @ £32
3. Non-Gen Aluminum skin @ £66
Apart from weight what other advantage is the aluminum one ???
It won't rust ?????
You'll probably have to bond it to the frame
You will have to use etch primer to prime it.
Aren't they just for racing purposes though ?
If the aluminium ones are aimed at racing I would think they are thiner and easier to dent. Need advice from the racing gang.
steeo
Post by steeo »
While I had the Cooper S brake setup apart to check the pistons and seals I decided to give them a blast, its amazing what 10 mins in a blast cabnet will do.
I was in contact with a company in Waterford that might be able to adonize (think thats the right spelling) them so just waiting on them to get back to me.
calipers 1.jpg (40.13 KiB) Viewed 6947 times
steeo
Post by steeo »
Never saw this sort of stud lock before but I suppose they had no liquid stud lock in the 60's.
Looks like they drilled a 1/8" hole in the bolt and inserted a piece of nylon or plastic.
bolt 1.jpg (20.74 KiB) Viewed 6876 times
GTM Coupe
Post by GTM Coupe »
Yeah quite common in both aircraft engineering and racing, the idea is that a S/S wire is tied through the hole, on a race car it is there as a form of locking or scrutineering sealing device, on a plane its there to stop the bolt from falling onto someones head in the event is fell out.
steeo
Post by steeo »
Got the spot weld cutters yesterday and started on stripping the door down.
Big hole on the bottom of the door
Door 5-640x480.jpg (69.12 KiB) Viewed 6757 times
Top rail
Top rail
Door 3-640x480.jpg (65.87 KiB) Viewed 6760 times
Door frame stripped
Door frame stripped
Door 2-640x480.jpg (82.49 KiB) Viewed 6761 times
steeo
Post by steeo »
They were very sneaky when they were putting these door together as some of the spot welds are hidden behind outer panels but after about 40 mins I got the door stripped.
Door 9-640x480.jpg (78.58 KiB) Viewed 6750 times
Door pocket out after a lot of work
Door 7-640x480.jpg (71.48 KiB) Viewed 6757 times
steeo
Post by steeo »
Well I am getting the finger out after a long time.
Today, arrived 2 box's of panels from Somerford with loads of goodies and I am hoping my new mig will be here early next week to get started.
Good to see your back working on the pick up again,If you want that jig for the doors give me a shout and you can have it anytime you want.
steeo
Post by steeo »
Need to sort out the frames first as they are bad and I can do anything till I get me new mig.
Will let you know about the jig Aiden, cheers.
any news steeo????
steeo
Post by steeo »
Things have come to a full stop with the pickup at the minute.
Space and time is my biggest enemy so I have been in contact with a mini specialist about the bodywork
and am looking at maybe this side of Christmas or the new year when they will be ready to take the pickup on.
Both subframes are ready to fit after both been fully stripped, sandblasted, seam-welded and painted.
Suspension got the same treatment, blasted and painted then were fitted with all new bearings and bushes (thanks to TMG)
Brakes, the rear were mostly replaced with new parts and the front discs and calipers were supplied by TMG (thanks again)
New fuel tank sourced again got a light blasting and was painted.
Other than the above all the parts now have a nice thick protective coating of dust on them. :D :D :D
briain
Whats your location?: Glenageary, South Dublin
Post by briain »
Will be looking forward to this always wanted a pickup what colour is it gonna end up and what you going to do engine wise
steeo
Post by steeo »
Will be putting it back to the original red if I can source it, as for engine wise that still has to be decided.
I have a choice at the minute of going for a 998cc, 1089cc (i think) or a 1275cc, i'll have to be talking to Paul (Merlin)
soon to see which engine would suit my needs better.
Miniman
Whats your location?: Cavan
What Minis have you?: 1966 850,92 city,98 2.5turbo R33 Nissan Skyline and a 1979 Mini Clubman
Modifications: To many to list!
Post by Miniman »
Looks like ill be taking over this build tread :D
Bending the rules,and ruling the bends,Since 1959!
