Nitros oxide
Nitros oxide
Thinking of fitting nitros kit,wondering what mod`s have to be done to engine.i.e different plugs,head,etc.Any help or suggestions would be welcome!
Re: Nitros oxide
Nitro gives the engine a right kick so you need to strenghten things like Head gasket, drop gears, diff, centre main bearing strap and cooling would want to be beefed up.
Re: Nitros oxide
You should get all the info you need at http://www.noswizard.com
Re: Nitros oxide
Thanks for info and advice
