Moderators: spud1979 , The Marcos Graveyard , Moderators
justcoupe
Posts: 33 Joined: Sat Sep 20, 2008 8:41 am
Post
by justcoupe » Sat Sep 20, 2008 8:49 am
Just after fitting straight-cut drop gears from mini sport,after fitting new clutch found that it would not work properly because the splines on the gears were not the correct profile
,3 hours work with valve grinding paste and new disc,just to get it to move freely.Beware of MINI SPORT drop gears,buy KAD!
Posts: 4724 Joined: Fri Feb 04, 2005 10:05 am
What Minis have you?: 1971 Mini Marcos. 1984 Mini Sprite
Modifications: 1380cc Weber45 S/C CR gearbox and drop gears
Post
by The Marcos Graveyard » Sat Sep 20, 2008 1:12 pm
What clutch disc were you using?
justcoupe
Post
by justcoupe » Thu Oct 02, 2008 5:36 pm
Have a new clucth kit,lever,slave+master cylinder and plunger.Its a non-verto clutch.
Post
by The Marcos Graveyard » Thu Oct 02, 2008 5:46 pm
So is it a problem with the clutch disc going onto the primary gear ?
Do you have the old helical primary gear, does the clutch disc fit on it correctly ?
justcoupe
Post
by justcoupe » Fri Oct 03, 2008 1:40 pm
It fits on the old one about the same as the new one.Moves pretty free on it too. My head is melted with this.HOLDING UP THE BUILD
Post
by The Marcos Graveyard » Fri Oct 03, 2008 3:28 pm
If the disc is free on the splines, then you need to check the pressure plate or flywheel assembly.
Any pics of it as it is now ?
justcoupe
Post
by justcoupe » Mon Oct 06, 2008 1:37 pm
Think I have it sorted,the bush on the top drop gear is the wrong size 2.5 mm bigger than the original bush,moving around on the shaft,cant believe I missed it.
Post
by The Marcos Graveyard » Mon Oct 06, 2008 9:56 pm
Ah, the old A/A+ transfer gear roller bearing size problem.
justcoupe
Post
by justcoupe » Tue Oct 07, 2008 1:36 pm
Was given a set for a 1275cc, P+T ENGINEERING are making up a new bush for me,should be back on track soon
Post
by The Marcos Graveyard » Tue Oct 07, 2008 4:01 pm
